Discuss Heating Bangs when switching off. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
When you say restrict the flow on hot water,is this when the system is running eg demand from heating/hot water? The hot water coil should have a balancing valve on it that should be restricted (which from the pic you have one after the 2port) to stop the heat just whizzing around the coil and giving less to heating
The balancing valve is fully open. When I mentioned restricting the flow I shut it off. Are you saying this valve should be half turned off or similar. Is this likely to contribute to the banging.
Cheers.
It should be restricted yes,but are you only getting flow through the by-pass valve when there is still demand for ch or hot water an your closing the balancing valve?
If I run the water and heating separately or even both of them together I can't get any water to pass through the bypass valve. I can only get it to pass through when I close the balancing valve with the hot water on demand.
Another point I forgot to add. If I turn the pump off at the fused spur, it doesn't bang. Don't know whether this has any bearing on the fault but thought I would mention it.
Cheers.
What size of pump is it, I can't read it
Photo attached. Cheers.
You don't really want water passing through the bypass when the valves are open so I wouldn't worry too much about that if the flow and return temps are ok at the Boiler.
I'm surprised it still bangs but you do need to rule things out like the lack of a by-pass before you can start to think of other possibilities,
I'll put my thinkin cap back on.
Cheers, it seems to be dragging on this but any suggestions I will try and I really appreciate all the help and advice.
Flow and return seem normal and all radiators get nice and hot.
I even tried balancing the system by restricting flow in the first radiator to warm up and so on.
I tried refitting the bypass valve with a normal 22mm isolation valve which I fully opened and it still banged. This would suggest an auto bypass is not required or not working even though the water is passing through and the pipes are hot.
When I am bleeding the system, when there is air present it doesn't bang. It's only when all the air is removed it starts to bangs.
Could the system just be full of glag as the filter is really dirty every week with bits of swarf/metal in it.
Thanks again.
Reply to Heating Bangs when switching off. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Boiler is SIRIUS THREE FS 70 Potterton commercial. Situation: We are small building contractors and my labourers managed to damage the radiator pipes during the strip out. Not the end of the world as damages happens. I am responsible builder and paying my bills and to repair the damages if...
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
