Discuss Heating but no hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Bob Ofelia
we have and ideal logic 12 boiler the central heating works perfectly but we have no hot water and the hot water tank is at a constant temperature of 23c never any higher
The pressure gauge on the red cylinder which Is in the same cupboard as the water tank the pressure keeps dropping on it and keeps having to be topped up
Does any one have any ideas on what the problem is
The boiler and water cylinder are both only a year old
It sounds like you have a problem with a 2 or 3 port valve . Just check your cylinder thermostat hasnt been accidentally moved / knocked . If its a new build or a new ish upgrade you will be quicker getting the original guys back , your gauge dropping is also another problem which requires attention.
You need to get the original installer back to check the system through. Has this been happening for a while?
Yes we're in a new build only been moved in for a year now
Newbuild is normally a 2 yr warranty if it's NHBC you may have to go through the developer/builder to get there heating Guys back
Reply to Heating but no hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
