Discuss Heating / hotwater controller replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all , can you recommend a simple to use and reasonably priced controller for a Y plan system please , friend has an antiquated one that needs replacing ( cant see the make)
cheers Howy
Drayton lifestyle
cheers Howy
Hi howy,
You could install a Honeywell controler
Reply to Heating / hotwater controller replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I need to replace my Grohe Geotherm shower cubicle mounted control unit. Its around 17 years old but replacements seem to be available The main hot / cold water control unit is in the loft, I think its working ok How do I get the replacement cubicle control to connect to the loft unit...
Hi, I am trying to link a Hive heating & hot water dual channel receiver to an old Vaillant THERMOcompact VU GB 242/1 E system boiler. It has an internal programmer that is similar to a time switch 120 (plug in seven day programmer) This programmer is connect to a terminal strip using 345 (three...
Hello, I have a gas boiler in my apartment that heats a net area of 300 m2 with an underfloor heating system. The boiler has a capacity of 45 kW. There's no issue with the heating system, but I want to increase the hot water capacity. I plan to connect an external 200-liter boiler. How can I...
Looking for someone that can replace the expansion vessel on an old heating system that is losing pressure every day and needs topping up at least three times a day. Trying to eliminate what the cause could be. Appreciate that it could be a leak somewhere, but looking to tackle one issue at a...
Looking for a bit of advice. My CH system has 2 controllers one for water and one for heating. I would like to replace these with one controller for bother heating and water contol. I have a Salus RT500RF which controls the heating and is mouted in the hall and is battery operated. In the...
