Discuss heating only turns on if hot water is turned on then off... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi, have a worcester highflow 4.5. working fine until recently where the central heating stopped coming on, although I can manually operate the diverter valve and have it heat that way (if I lock the diverter valve open). So I thought the synchron valve was the issue, replaced that. Now it seems that the only way I can get the central heating to come on is if I turn the hot water on the off again... or lock it in place like before. (making the timer redundant). any help would be greatly appreciated.
thanks
coby
Have you checked there is a live feed to the diverter valve from the external controls?
Reply to heating only turns on if hot water is turned on then off... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always amazed at the water pressure so on the odd occasion that the water was only luke warm it was easily forgiven, but over time we have come to realise that...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the outputs goes to a 2 port diverter prior to the Megaflo (I believe this is some safety feature). I have run into an intermittent problem where some...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem could be. We have a biomass boiler and stratification tank set up and recently had an issue with boiler pressure dropping off when the system was cold...
I recently read a post / comment whereby there was a recommendation that if you are away from your home more than 24 hours, then you should turn the water off to avoid potential catastrophic damage. When I go away I have always tended to turn ours off, that's typically anything from a couple of...
Morning, Moved house a few months ago and first issue is having a slight leak on tap in kitchen. Went under sink to turn off water and there are four valves I can see as per attached photos. Tried turning all clockwise 90 degrees as per usual but water still coming out of tap. Am I missing...
Deleted member 120897
