Discuss Heating systems installation in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Plumber 78
    Plumber 78 New Member
    Hi to all. Have quoted from two heating engineers for my new heating system. One with low loss header and three pump(hot water cylinder,heating zone 1,heating zone 2),one with out. The house is 5 bedroom with loft conversion and back extension,will have 20 radiators and 300l hot water cylinder. Can someone give me a advice what is the best choice,because it’s a big difference with the price. Thanks to all.
  2. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    What’s there at the minute? and was it all working ok before you needed it all upgrading?
  3. Plumber 78
    Nothing is there,builders just finishing loft and back extension,before is very poor gravity system.
  4. ShaunCorbs
    Are you having multi zones and under floor heating ?
  5. Plumber 78
    It will be a 2 zones of heating and 300l hot water cylinder ,no underfloor heating.
  6. ShaunCorbs
    I would go with the llh quote it will future proof your property
    • Like Like x 2
    • Agree Agree x 1
  7. Plumber 78
    Thank you
    • Like Like x 1
  8. Plumber 78
    That’s make sense,don’t want on the end of the day to have some radiators half could,thanks
  9. SimonG
    SimonG Trusted Plumber
    The guy with the three pumps/zones and the low loss header sounds like he knows what he is doing.
    • Agree Agree x 2
    • Like Like x 1
  10. Plumber 78
  11. Chalked
    Chalked Plumber GSR
    As above.
    Anyone who would be using a low loss header, is on the ball.
    • Like Like x 1
  12. king of pipes
    As the chaps have said a system with a low loss header would be ideal . cheers kop
    • Like Like x 2
  13. Matchless.plumb
    Matchless.plumb Trusted Plumber GSR
    What’s the mains water supply like? Did you upgrade the mains supply? What’s the info 8ng mains pressure and flowrate ?
  14. Plumber 78
    Yes,main upgrade to 28mm,but pressure is only 1.5 bar, thinking to fit like that device,but not decide yet.
  15. Plumber 78
Loading...
Similar Threads - Heating systems installation Forum Date
Advice for heating system to install Central Heating Forum Jul 12, 2018
Certificate and Qualifications for Central Heating Central Heating Forum Jun 21, 2018
