Discuss Heatline c24 warm water! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hobo128
Any help with this rubbish boiler would be helpful.
Open hot tap and water is only warm. Display says 30c . Changed diverter cartridge but no good, check plate heat which seems fine.
Does it fire when hot tap is opened ?
Have you checked temp sensor ristance ?
Sounds like its not going onto full burn, PCB or Gas valve maybe ??
Hw thermistor maybe .
What temp diff have you going in and out of the plate
Reply to Heatline c24 warm water! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
