Discuss heatrae sadia 25l 9004010. in the UK Plumbers Forums area at PlumbersForums.net
Maybe worth checking that for scale build up, if its restricted then the flow from any hot tap will be restricted as well except its just a pure vent pipe,, any photo or description of the unit?.
I have a upstairs "1/2" cartridge tap gravity fed from ~ 0.25M that flows 4.0LPM, so if the water level in your cylinder is, say 0.15M above the tap then you might expect ~ 3.0/3.1LPM.
The distance between the base of the cylinder and the hot tap outlet is around 1meter. So this would give 0.1 bar pressure. What flow rate would this likely give?
If it does flow at a decent enough level. If were to fit dual flow taps. Doesn't mix in tap mixes after leaves the spout. Would single checks not be needed to avoid back flow
Reply to heatrae sadia 25l 9004010. in the UK Plumbers Forums area at PlumbersForums.net
