Discuss Help designing an offset soil pipe vent in the Fittings & Pipes area at UKPlumbersForums.co.uk.
  1. Rypat
    Rypat New Member
    hello,
    I am designing a soil pipe for a timber bungalow that I am building where the soil vent pipe needs to be offset on a gable wall away from the main soil pipe. I have put in a link to a drawing I have made with my idea. Your advice is welcomed
    Dropbox - plumbing layout (1).pdf
  2. Last Plumber
    Last Plumber Plumber GSR
    This might be a daft reply but, Two 45 deg bends and a piece between?
    If it's the travel length you want to calculate, then you need the two centres times 1.414 less the legs. (for 45 deg).
    I don't fully understand the problem so if I have not answered it, please let me know
    • Like Like x 1
  3. Rypat
    Rypat New Member
    that’s what I was thinking. Do I put the Y branch for the soil vent so that the toilet feeds into the Y or the vent pipe feeds into the Y. Can you have any horizontal sections in the air vent pipe?
  4. Rypat
    Rypat New Member
    In case the Dropbox doesn’t work...
  5. Last Plumber
    It's just a vent isn't it?
    As long as it goes past any opening into the building by 3 foot it's fine.
    If I understand what you're asking and you mean a junction with the WC entering the branch and the vent off the top, yes.
  6. Rypat
    Rypat New Member
    Yes. I think the drawing shows it more clearly than I can explain it
  7. Last Plumber
    I see what you mean. Just studied pic a bit closer.
    Any other vents ?
    Why take it around the house? is there a reason why it can't come up where the WC Soil exits the building ?
  8. Rypat
    Rypat New Member
    No other vents planned. I wanted to keep the stack pipe out of view as that gable is out of sight. Also keeps pipe from going through the roof or round the roof with an offset
  9. Last Plumber
    What does it say on the drawing in the corner?
    Does it say pumping station?
    Is it not main sewer?
  10. Rypat
    Rypat New Member
    It’s going to a sewage pumping station up to our mains drain
  11. rpm
    rpm Trusted Plumber
    Should be ok however check the MI`s or call them with the measurements.
Loading...
Similar Threads - Help designing offset Forum Date
Combi CH seems to be randomly working, HW is fine, Help! Central Heating Forum Today at 12:24 AM
Soil stack query?? Help Plumbing Forum May 15, 2018
