Discuss Help I have a drip on the washing machine tap I think. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello,
I am no good at DIY but came here for help on a plumbing problem.
I have a small leak as per picture attached, I think the shading machine tap needs replacing but I am not sure.
Have checked the copper piping that appears fine, but the drip appears to be coming from the machine tap.
The y plastic tap above appears to be fine. To repair the issue is this something easy to do myself plus the part wise?
O I tried my best to seal the leak but it is not working hence the tape on the pic.
Two possibilities at first glance:
1. Rubber seal inside beige plastic lower nut on Y piece is missing / damaged - replace Y piece.
2. The blue plastic handle on the tap is preventing the beige plastic nut from tightening up sufficiently. Remove blue plastic handle. There will be a small machine screw attaching the handle to the valve spindle.
Looks like it's leaking from the plastic y there not very good and best replaced
http://www.NoLinkingToThis/p/compre...gclsrc=aw.ds&dclid=COiVg5j6htYCFUPIUQodPk8LtQ
You can do it yourself if you have hand tools grips and an adjustable spanner
If not should cost too much for a plumber
Check my link two posts up
Is this Defo the right part as per pic the blue handle piece seems to bend not have two ports to it. I think the y pipe is the issue as you can see the water coming out just where the plastic nut is.
They leak all the time there rubbish best to replace either either two washing machine valves or the one in my link above
Nope no difference just two 3/4 connectors
Hello I have another issue regarding the bath itself
Recently a screw has come lose under the bathroom tap, the rubber has worn away on the screw. I think the other one is on its way out as well.
I have attached the photos can anyone help with this?
Reply to Help I have a drip on the washing machine tap I think. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Hi there, Please excuse my lack of knowledge on this, my plumbing knowledge is very limited. I have a cold water feed going into cistern with plastic pipe and push fits. It's a new built in cistern. I am looking to tap into the feed and add a water supply for a washing machine. Can I just...
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a steady stream without stopping. Seems to be coming from water heater but I cannot tell. It is cold water. When I turn off the main water supply, it...
Pritesh Patel
Hi, I have just moved the washing machine into the garage and it will not drain. I wonder if it's something to do with the way I have installed the waste? The washing machine is only a month old and was working fine this morning before re-positioned. I put an 1100mm hoorizontal run at around...
This is probably obvious but I want to replace the cartridge to stop dripping. I have done similar before but I cannot work out how to remove the tap head! i thought the hot/cold circle would pop out but no such luck and don't want to damage. can anyone help? Thanks Martin fix the caple
K
I am plumbing in my washing machine and the copper pipe with blue tap/switch on it has no water from it when you open it. The hot version works fine. Both are side arms from the nearby sink supply which both work fine. Help much appreciated! Thank you.
KateTa
K
