Discuss Help identifying a pipe please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone I’m looking for a little help to identify a pipe so far I think the below is correct (see pic)
A - hot from boiler
B - expansion to expansion tankin loft
C - control for hot water tank
D - control for central heating
E - return from hot water tank coil, return from central heating T’s into it from the floor I believe
F - goes upto expansion tank
Now the one I’m not sure about.
What is pipe G, I was thinking some kind of expansion again maybe for central heating but it has a valve that seems unwise for expansion.
Any ideas?
Whole system both central heating and hot tank are vented.
Many thanks
James
Not sure why the valve has been fitted on the feed pipe there. It shouldn’t be on any feed pipe
Reply to Help identifying a pipe please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to connect to the heating system, So while the wood burning on during winter months it will stop the heat pump for working hard Or not all all . My...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
Hi I recently did some pipe insulating in my loft. The only two I didn't do were the vent pipes. Not sure if that is the right term for them? They are the pipes that feed water back into the top of the tanks when there is excess, presumably from steam, expansion, etc. The one going to the cold...
My daughter's place has a small water leak on a ground floor radiator valve. The radiator pipework is small diameter.i.e 8 or 10 mm. A plumber is coming back in a day or so to make necessary repairs. I am a little concerned as the house has a Boilermate 2000 on the upper floor and the...
Hello, I live in a two floor semi with a gravity fed conventional gas fired boiler (Potterton Kingfisher MF). The boiler is fed cold water from the loft water reservoir tank (which also feeds the cold water taps in the bathroom & the WC cistern). There is an expansion vessel attached to this...
