Discuss HELP leak under boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
please help.
I have a Worcester boiler. last serviced 11 months ago. I've just seen huge water stains on my ceiling. I've come upstairs to look at the boiler and the whole area underneath it is a pool of water. I can see slow drips of water coming from the white pipe. I don't know the terminology of what the pipes are called so will put a photo. there is something that I gather from Google is called a tun dish. this is full of water and the water is coming from under there. the boiler is currently still on and working fine.
If the tundish is full of water it sounds like your condensate is frozen outside and blocked which has back filled the condensate and it’s now cascading over tundish now it’s full
ive seen some links on facebook about that. our boiler has been working. i can't access the outdoor pipes as boiler is up in the loft (lift is converted to a bedroom).
Your boiler would continue working as you have had a tundish fitted which will allow the siphon inside your boiler still to flush through condensated water and unfortunately spill all over your floor where as others that do not have the tundish fitted the water is backing up into the boiler cause ignition failure
time to call a gas safe engy out then sorry to say as its frozen
The white pipe and tundish is likely to freeze as well
thanks for your responses. I have a bowl under the leak at present and will hopefully be able to get someone out tomorrow:)
I checked at 5am and it was still dripping. just been up now (10am ) and the bowl is empty.
maybe it was a frozen pipe that has now defrosted? will get someone out to check
Could be
Reply to HELP leak under boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On further inspection I discovered that water was coming from boiler cupboard. On looking in boiler cupboard I found boiler has started leaking water...
I have a leak from my shower, it's coming down into my kitchen. I've had the sealant, waste pipe and tray all checked. I've also had the shower controls checked. Weird thing is the shower leak only happens when there's weight on the shower tray. The shower tray doesn't flex in any way, which is...
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and the other seems to be near waste tray, there is a slight hairline crack in shower tray near waste . This happens when I leave the shower head near the...
I had a potential leak in the island kitchen drain, but it's no longer an issue after using an auger through the clean-out pipe. The water seemed to be coming out from the base of the pipe. I've removed a section of drywall for inspection purposes. After filling both sinks with water and...
My son moved to a new build home in Cornwall last November. Yesterday evening he found a quantity of water beneath the Ideal Combi boiler and a steady water drip from the boiler. After clearing up and putting a container beneath the boiler, he went to bed. This morning the water drip had...
