Discuss help me understand this heating system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My mother just moved and I'm trying to figure out her boiler/etc.
We have some kind of boiler in the kitchen, and below it there's a controller with individual on/off settings for hot water and central heating. There are no controls on the boiler itself.
There's a thermostat in the hall.
There's a hot water tank upstairs in an airing cupboard. I think that also has an electrical immersion heater.
The first thing is that the hot water from the taps is very hot. I'd like to be able to cool that down a bit.
But, overall, I'd like to understand how it works.
You see, in my flat, I have a boiler with settings on it, one each for water and radiators; and there's a thermostat in the hall. It's pretty simple really.
Where does the immersion heater fit in? How to control the temperature of the tap water?
TBH, I'm not entirely sure how to describe some of this stuff, so please forgive me if I've not given some crucial bit of information...I'll happily go and look.
Max.
Sounds like a heat only boiler with a copper cylinder
Any chance of a picture of the cylinder cupboard, need to check some things first (could be two different types of systems )
on the cylinder behind the grey cover under the badge is the cylinder thermostat but be careful as there are wires and elctrical connections in there you can make the cylinder water cooler by turning the thermostat down
That's great
Heat only boiler in s plan set up with an unvented cylinder
Boiler controls the grey flap flips down and there will be a temperature dial / knob there (this controls your rad temps)
Hot water thermostat is located on the cylinder under the grey panel / cover (one screw and should open like a door) this is normally pre set to 60 dc to kill any bacteria off
So best to test the temperature first before changing anything (temp probe under the kitchen tap)
If it's around the 60 mark (55-65) then this is set right, if you think it's too hot for your mother you might need to go down the route of having a tmv3 fitted ( mixing valve like a shower)
Now for how it works
Heating
Time clock heating programs comes around
Room stat senses house is cool / below set temp
Myson port valve opens (white top)
Boiler fires and pump starts
Room stat upto temp
Port valve closes, boiler stops and pump
Hot water
Time clock hot water programs comes around
Cylinder stat sense water isn't upto temp
Honeywell port valve opens (silver top)
Water reaches desired temp (via cylinder stat)
Immersion heater is only for a back up incase there is a problem with the boiler, you can still have hot water
Reactions: pip
That's great! Thanks guys. I'll check out the thermostat on the cylinder, after sticking a thermometer under the tap. 60C sounds quite hot, so perhaps it is correct....we'll see :)
How does the immersion heater know there is a problem with the boiler?
It doesn't know mate, you will have to switch it on yourself if the boiler develops a problem. Usually via a switch somewhere, just follow the wire that comes from the immersion heater to its switch.
Ah, ok. I suppose it is plausible that it might already be on...I'd better check it :)
/edit no, it wasn't on :)
Reply to help me understand this heating system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any kind of instructions/manual and therefore trying to figure out ourselves. We have what looks like a boiler/water tank system (coming from a standard...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the outputs goes to a 2 port diverter prior to the Megaflo (I believe this is some safety feature). I have run into an intermittent problem where some...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always amazed at the water pressure so on the odd occasion that the water was only luke warm it was easily forgiven, but over time we have come to realise that...
Hello, I've just found this forum and wondering if anyone can please help us. We've not long moved into our new home. It's has Johnson and Starley warm air heating and hot water tank in airing cupboard. All has been working fine until yesterday. We had the water softener serviced and since then...
K
We have a dual heating system, a solid fuel stove with back boiler and a external kerosene heater. The kerosene heater is working fine heating the radiators and the water for the taps The solid fuel stove will heat the water for the taps but the radiators will only get luke warm. Can anyone...
