Discuss Help Needed Please Re Shower Pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have just had a complete refit of my Bathroom and the toilet was boxed in and the plumber decided a good place for the shower pump was inside the boxing However after he finished we could smell an odour of the sewer and when I looked in the boxing the Plumber has left the shower pump on the cardboard box the pump came in and it is not fixed to anything and the box is pushing against the waste pipe and I think that is the reason for the smell. I asked him that just leaving it ontop of a cardboard box seemed a bit odd and he said it is to stop the vibrations of the pump being noisy Is this a normal procedure also he has connected this to the toilet so when we flush the toilet the pump activates to fill the cistern am I worrying about nothing just doesn't seem very professional to me ? Thanks
Don`t pay him and charge him for his horse eating your lawn.
I wouldn't connect the pump to the toilet but have seen it many many times. Pumps getting much quicker faulty due the fact that pump is activated each time you flush. Once the fill valve lets by the pump starts running on and off all the time.
However, as rpm has mentioned do not pay him.
And sometimes I worry if my work is good enough. Seriously: a cardboard box? If he'd mounted it but left the the box around it as sound attenuation I might call it alternative technology, but, as it is...
Many thanks for the replies
What is annoying about this is he was recommended by a friend as an excellent bathroom fitter and it seems like he has used speedfit fittings everywhere I thought speedfit was for the amateur plumber no offence intended if its not. He wasn't cheap either !
Can the pump being connected to the toilet cause any damage to either I realise it may wear the pump out quicker and why would he do this I am not sure why he even did this as it obviously doesn't sound like the norm is he cutting corners in some way ?
Reply to Help Needed Please Re Shower Pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar. Connect to this is a 1.5 bar Ora Salamander pump for a positive head, this was connected by a plumber of course and we’ve had it all rigged up...
Hi - I am looking for help regarding new shower pump. -its new -it always stays on when the power is on. It should only switch on when water goes to the shower -its noisy Can anyone advise please? Many thanks Iain
Hi All As you can see from the attached pix, the flow control knob on my Bristan shower has broken. It was installed before I bought the house (possibly between 2015 and 2017) but I've no idea what model it is. Firstly, can anyone help me to identify it to see if I can get a replacement knob...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
Hi, I need some help on this shower drain installation. I’m about to install a corner shower kit in my basement bathroom. But I just found out the shower drain is actually extruded from the bottom of the shower base and I have concrete floor with the drain pipe rough in. I have the drain pipe...
