Discuss Help - Vaillant EcoMax Pro 18E in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Tearing my left over hair out. Boiler is just not activating
Fault Code 11
Sub screen code - Flame picture with Electrical sign, Code 2
Symptoms
- On switching on Boiler - Slight ,i mean slight, jerk on fan as if it was
going to start
- Pump does not switch on ( pump checked, works)
Tried
1) Motherboard Changed
2) Voltage checked as per valliant Fault finding diagram
Ask Vaillant | Domestic Boilers | Vaillant
Suspicious of Fan ?
If Fan is defective, would the pump Not switch on ?
Have explored all over and just cannot reach any decisive answers
My presumptions is on start up ( if there is a demand )
1) Pump Would switch on
2) Then Fan would start up ?
The LED status is showing Green
I have attached a document with the fault pics
Any pointers / solutions would be much appreciated. Am relatively new to this field and trying to find my way around ( slowly ) through fault finding
  • ukplumbers.Upload.pdf
MI's state F11 = Connection fault between main PCB and interface; Faulty interface; Faulty main PCB (processor), Check fan
Hi Minotaur Welcome, You might not get much more help until you show GS Registered.
Hi - Yes - I went through all those process's ie Interface, new PCB etc. Although "Check Fan" is rather ambiguous
I am GS registered. Have entered my membership number. Unsure how else to show it ? Mind you, have only registered on to the site this morning
ah - Yes - Mods :)
Yes, there is voltage supply upto the fan. Have checked the voltage and it matches broadly what is specified
Send us your gsr number
And do 10 (7 more ) non spamming posts
Thread closed until it's moved
Reply to Help - Vaillant EcoMax Pro 18E in the Plumbing Jobs | The Job-board area at PlumbersForums.net
