Discuss Help what heating system is this?? in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Keeley
    Keeley New Member
    I am currently purchasing a property that has a cooper boiler. However in a couple of rooms there is small brown boxes that appear to look like speakers. However the estate agent seems to feel they are part of the heating system any advice would be great I have attached a picture for reference thanks
  2. ShaunCorbs
    It could be warm air unit but we would need better pics
    • Optimistic Optimistic x 1
  3. jtsplumbing
    jtsplumbing Plumber GSR
    Need better photo, but may be Myson fan heaters, that work off heating pipes , are there any radiators in the rooms ?
    • Like Like x 1
  4. Keeley
    Keeley New Member
    Yeh there are radiators in the room also running off cooper boiler. There is one of those brown boxes in two bedrooms then in the living room a larger brown box with dials but I haven't got a picture of this until I get the keys. Just trying to find out some information so I know what to expect. Thanks
  5. jtsplumbing
    Could be some sort of heat recovery system ?
  6. scott_d
    scott_d Plumber GSR
    Baxi Bermuda wall mounted heater?
  7. jtsplumbing
    Seems strange as he's got rads has well, be interesting to see this box with the dials on
  8. Keeley
    Keeley New Member
    As soon as I can get more pictures I'll up load them. They look like speakers from the front like s mesh material covering them and on the size is like a removal cover a bit like the back of a remote. The house is very old fashioned inside so just hoping not a major job to remove.
  9. Keeley
    Keeley New Member
    The removal cover is just to the side of the box.
  10. scott_d
    scott_d Plumber GSR
    You should probably budget for a modern heating system
  11. jtsplumbing
    is the
    Is there any pipes going into the units ?
  12. Keeley
    Keeley New Member
    None that are visable
  13. jtsplumbing
    No pipes then its not connected to the heating system maybe it is some old sound system after all
  14. Stoney Ground
    Stoney Ground GSR
    Either look for a room stat or a volume control:rolleyes:
    • Funny Funny x 1
  15. Keeley
    Keeley New Member
    The rooms up stairs have been applied with polystyrene tiles so no pipe work is visable from just looking I guess I won't know more until I remove tiles once keys are released. I was just hoping somebody knew what they was from past experiences thanks
Loading...
Similar Threads - Help heating system Forum Date
Concealed Cistern - help with changing flush valve Plumbing Forum Friday at 10:20 PM
Help with sizing radiator Plumbing Forum Friday at 8:56 PM
