Discuss Help with my Y plan heating system please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi everyone
I’ve noticed a small issue with my heating and it’s bugging me because I can’t put my finger on what’s causing the radiators to randomly come on when our Nest therm is off.
I don’t think the Nest is at fault because the heat link is not showing “Heat on” lights when the boiler randomly fires up.
I don’t think the valve is at fault either as it’s brand new, replaced last summer.
My only thought is it must be a frost protection setting as we are in winter and this mostly happens at night, although it’s happened today when it’s 6 degrees.
Is it normal though for the rads to heat up when this happens? Also the temperature on my thermostat shows high in the mornings, so there has definitely been a lot of heat throughout the cold nights, again when I don’t have any heat scheduled at all on my Nest.
I’m quite good with electrics and have done some process of elimination tasks, I’m convinced it is something to do with frost protection, but don’t know how to fix this, also my heating bills are rising, which is why I need to find this fault.
Any help would be greatly appreciated.
If your heating bills are rising, turn the room stat down?
The only way to tell if your consumption is falling is recording the usage, every month, over a long period.
Also, remember this winter has been colder than the last couple!
Unfortunately last summer is not new. A valve is only as good as long as it has been sat on someone’s van. (Could of been on there 18 months before he fitted it). It is the first place to start. Put the hot water only on and see if the pipe to the rads gets hot.
Reply to Help with my Y plan heating system please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to connect to the heating system, So while the wood burning on during winter months it will stop the heat pump for working hard Or not all all . My...
Hi thank you for letting me join this forum . We have an air to water heat pump but the bungalow is piped in micro bore 10mm pipe which doesn’t look well piped , kinky in pipes in some places ,some of the rad don’t heat up too well , probably because of the badly piped system, the pipe is all...
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any kind of instructions/manual and therefore trying to figure out ourselves. We have what looks like a boiler/water tank system (coming from a standard...
My son has just had a new boiler fitted and hes noticed that the pump runs 24x7 even when both the heating and hot water are set to off. He’s also found that when the hot water is set to off on the programe timer, the boiler is still heating up water. I wonder if this is because the engineer...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
