Discuss High Boiiler Pressure in the Central Heating Forum area at UKPlumbersForums.co.uk.
Tags:
  1. fadsarmy
    fadsarmy New Member
    Hi everyone. I have a Vailant turbomax plus 837e boiler. Just checked the pressure and noticed it was just under 3 but is working fine. It was 1.5 when I checked a couple of weeks ago. Is it something I could attempt to sort out or do I need to call out an engineer. Also, is it safe to continue using?
  2. scott_d
    scott_d Plumber GSR
    Bleed some water out from a rad air vent or drain off
    Disconnect the filling loop as it could be passing
    • Agree Agree x 1
  3. Darren Jackson
    Darren Jackson Plumber GSR
    I Agree with scott_d. Drain some water out & make sure the filling loop is not passing by turning the valves to it fully off and then take off the connecting hose. put an 1/2" female cap on the end of each valve. If the pressure still creeps up then you will need an engineer to check the expansion vessel, amongst other things.
  4. fadsarmy
    fadsarmy New Member
    Thanks for the reply guys. There's no filling loop just a valve which you turn with a screwdriver.
    • Optimistic Optimistic x 1
  5. rpm
    rpm Trusted Plumber Top Contributor!!
    Have a look for a braided flexi hose with valves and handles each end, they are not always close to the boiler.
  6. Darren Jackson
    Locate the filling valve handle on the cold water inlet
    filling valve under the boiler & make sure it is fully off. Then you have to remove the filling valve handle and locate on return filling
    valve and turn that one fully off as well. There is a flexible filling loop on these boilers its just hidden. Once you're happy they are both turned off properly then remove valve handle and refit on cold water inlet. and take off the connecting hose and cap open ends.
  7. Darren Jackson
    Sorry forgot to mention you have to take off the lower cover plate underneath the boiler to access the built in filling loop. It can be safely removed by you simply unscrewing it without compromising the boilers safety or breaking any seals.
  8. fixitflav
    fixitflav Member
    My son had a new combi a couple of years back and I'm pretty sure there is no flexible, just rigid pipe with a valve each end.
    Can't remember whether it's a Vaillant.
    I think the valve on the mains supply is 3-port, so in the Fill position flow to the heat exchanger for HW is stopped, to avoid a problem of somebody turning a hot tap on when you're trying to fill. The ones I've seen with a flexi don't have that feature, each valve is on a tee.
  9. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    The filling loop is built in on yours mate. I believe.
  10. Harvest Fields
    There should be a hole in the centre of the slot where you are using the screwdriver on. Use an alum key and make sure it is fully in the off position.
  11. fadsarmy
    fadsarmy New Member
    Thanks. How do I know the off position? When I turn it either way there's no sound of water movement like there was previously.
  12. Harvest Fields
    Or does it look like this?
  13. Harvest Fields
    If it looks like above there should be x 2 of them (If I remember correctly) but I have been wrong in the past:D
  14. fadsarmy
    fadsarmy New Member
  15. Harvest Fields
    A radiator bleed kit should fit over the square bit. Should make it easier to turn
Loading...
Similar Threads - High Boiiler Pressure Forum Date
Worcester Greenstar Highflow 440 intermittent hot water Gas Safe Registered Plumbers Only Aug 29, 2018
Valiant ecotec plus 831 high/low fire settings Gas Safe Register Forum - Public Forum Aug 9, 2018
