Discuss Hive fitting on Greenstar HE plus in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Colins1967
Hi All
has anyone fitted a Hive on a Worcester Bosch Greenstar HE Plus, Bosch says to can't be done due to the software,
I think you'll find the manufacturer knows their boilers.
Even if you could, you'd need to be a gsr.
So, because of that.......
Reply to Hive fitting on Greenstar HE plus in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an issue with a Worcester Greenstar 29CDi Classic boiler. I replaced the old thermostat controller with a smart dual-channel HIVE one. I did all the wiring following the diagram in the attached picture. The boiler doesn't work anymore. Please, any suggestions?
Hi I am trying to fit a Hive Radiator valve into my existing TRV valve body to make them automatic so have bought a Hive valve to try it out. I have done this before in another install but the valves were Danfoss and directly compatible with Hive. I am looking for an adapter that will be able...
Hi Everyone - despite my best efforts I can't seem find a clear answer on how to wire a single channel Hive Receiver to a Worcester Bosch Greenstar 4000 30kw. I've attached 2 photos showing the connections on the receiver and boiler. With great hope you experts out there can help - thankyou!
3K
J
Morning all, My Vallient Ecotec Plus 831 is stored in the loft and is connected to Hive. It is coming on randomly at various times of the day, but particularly middle of the night, and staying on until I manually turn the boiler off. Hive schedule is switched off but still comes on. Had an...
J Hughes
J
Hi, I have a Worcester Bosch Greenstar 30Si combi boiler, the analog clock has stopped and the On-Timer-Off switch only works on Timer setting,. So I have set all the little timer switches to ON and the boiler does work then. Any help or source for a new clock would be great. TIA
