Discuss Hive - Potterton EP3000 - help in the Central Heating Forum area at UKPlumbersForums.co.uk.
Tags:
  1. stevens1975
    stevens1975 New Member
    Hi guys.
    I have a Potterton EP3000 remote controller and a Worcester Greenstar Camray Utility 25/32
    I've upgraded to Hive but I've got a problem. I can fire the hotwater up and the boiler kicks in, however, when I try to fire up the CH, the hive registers that the central heating is on but the boiler doesn't fire up.
    I've attached the following pictures
    1) Old Potterton wiring
    2) Hive wiring
    3) wiring in box by boiler.
    4) wiring box cover
    Any ideas on what I've done wrong please
  2. ShaunCorbs
    Pic of the back of the old prog please
  3. stevens1975
    Back of the Potterton
  4. ShaunCorbs
    That's great
    Do you have two port valves or a 3 port
  5. stevens1975
    Its a two port.
    attached is a photo of the set up in the airing cupboard if this helps.
  6. ShaunCorbs
    When you link 4 and 5 on the old programer does the boiler fire for ch (you might need to turn the room stat up )?
  7. stevens1975
    The wiring is how it was on the original programmer and we've never had a room thermostat before. When you up the temp on the hive it show the central heating to be on but the boiler doesn't fire up
  8. ShaunCorbs
    Link 4 and 5 on the old prog boiler should fire on ch
    (Wires in a choc block together)
  9. stevens1975
    The old programmer has been removed and everything worked fine before.
  10. stevens1975
    Are you asking me to put the old programmer back on and change the wires?
  11. ShaunCorbs
    No just choc block them two wires together that went in 4 and 5 on the old prog
    Will test if it's a wiring fault or something else
  12. stevens1975
    Hi
    Have choc blocked wire from 4 & 5. (as per attached pic) Still CH not kicking on. Do I need a wire to go into no 4?
  13. ShaunCorbs
    No as it should fire independent of the hive now
    If you can remove the Earth wire from the chock block and put it into the live terminal on the new backplate
    Heating should fire
  14. ShaunCorbs
    TBH there always a pain I would recommend re wiring it
  15. stevens1975
    What do I do with the blue wire that left in the choc block?
Loading...
Similar Threads - Hive Potterton EP3000 Forum Date
Potterton performa fan fault Plumbers Arms Jun 4, 2018
potterton ec three 215 e Gas Safe Registered Plumbers Only May 4, 2018
  1. potterton ep 3000 direct replacement
