Discuss Hive self install ideal eco spirit 24 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all
Sorry im new i have a new combi system ideal ecospirit 24 im trying to wire up a hub reciver iv managed to get power to device looking on advice on how to hook up to control it at the moment its got a loop connected to a mechanical boiler timer with manual on and off iv tried to remove the loop and the boiler stays in standby mode here is the diagram of the circuit and was just wondering what ones need to be wired up to hive faceplate
If anyone can help please
sorry to say you cant do any wiring inside the boiler so your best option is contact a heating engy
well theres no point of a self install iv got power running just confused over the wiring to connect the thermostat up
Hi welchy , unfortunately it's only a self install on certain boilers , most sealed boilers like yours require breaking the combustion seal ( removing cover ) which is the boilers exactly worked out air supply , by interfering in that u break gas safe rules pal, older boilers and even some new you can instal the hive without a gsr,
Boiler dont have any seals the panels for the pcb board is just a flip down panel and wiring can go stright in to it it didnt have a thermostat installed with it
You've removed the front boiler panel which is the seal I'm not debating it
Thread closed
Reply to Hive self install ideal eco spirit 24 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
