Discuss Honeywell Evohome good or bad. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm thinking about installing a Honeywell evohome system in my own house. It looks good on paper but I'm still in two minds as it's a lot to spend. Has anyone out there got experience of fitting or operating it?
Yeh fantastic system but expensive, Massive control on every room if getting the full kit , well worth it ,
Agreed lot of kit for your ÂŁÂŁÂŁ
I had this installed in December 2017. I had some teething problems with the installation as it showed up some faults that were there, but undetected, in the original heating system.
The hot water zone valve was sticking and partially open (sometimes) and the hot water was not being correctly controlled. Now replaced.
Two of the original TRVs were not operating correctly and were casing vibrations in the pipework when partially open. This became much worse when a radiator was replaced and the TRV moved from flow to return. In investigating the cause I found a second original TRV that was also causing vibration. Both of these TRVs have now been replaced and we have no further vibrations.
I have had a problem as yet not resolved where a radiator control head loses connection to the Honeywell controller. It can take over two hours for it to reconnect. It has not done this for over two weeks. The RF checks show a signal strength of between 4 and 5 (max). Whether the vibration was causing this - who knows?
Apart from these issues it is proving very easy to set and change timers for each room. We have 12 zones. The radiator controllers make a whirring noise when adjusting but is is not too annoying.
I can't yet judge whether it will save any money as the winter has been much colder than last year and we have only been in the property for 18 months.
I had some difficulty finding an installer. The Honeywell web site had a feature to invite installers to contact me but I am still waiting. The first two heating engineers disappeared (no response to emails) between the first contact and 6 months later deciding to go ahead. I did eventually find a local company that had installed a small number of systems and so seem to understand it.
I did a lot of research into competitive systems and in particular about any security vulnerabilities (by profession I have been a network security specialist - now retired - responsible for the integrity of a number of critical systems). For example I would never accept a system that depended on having a mobile phone as the sole means of controlling it. There is too great a risk (in my opinion) of a compromise revealing whether the premises are unoccupied = heating switched off) and Honeywell's competitors did not seem to understand this issue. Honeywell also refused to answer my questions, or reveal their communications protocols, but their Evohome system will operate without Internet access which makes me feel a little more comfortable and I judge the risk to be just about acceptable. It is not regarded as good practice to rely on security by obfuscation. Security measures should be open to critical inspection by experts (far more capable then me) in order to be trusted.
I am however pleased with the end result so far.
Reply to Honeywell Evohome good or bad. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Honeywell ST699 programmer which is working fine but I want to learn how to decommission it (disconnect it from the rest of the system). Currently I have a Honeywell Home Single Zone Thermostat (Y87RF2024) and I am thinking to get the Honeywell Home Mobile Access Kit RFG100 to get...
Is there any advice on using Honeywell Evohome with 2 zone heating. Honeywell support are pretty useless and give conflicting advice. They suggested I ask my installer (but my installer suggested I ask Honeywell). I found a support article on the Honeywell Resideo website by Googling...
1K
We have a Megaflo CL210 Cyclinder along with Evohome hot water kit and have come across a problem. We have had solar installed and a Myenergi Eddi solar diverter for hot water but when the Honeywell was originally installed they removed the bottom thermostat probe and inserted the Evohome...
Hi there, I'm considering having my heating system controlled by Honeywell Evohome. I have a question about the underfloor heating controller.... I have a single zone water underfloor heating in the kitchen. The controller is currently a Wunda. I've never been all that happy with it because...
Looking for a quick bit of advice since I'm trying to wrap my head around what work I need done. Right now I have an old conventional boiler that heats my hot water tank. The water tank has manual open/shut valve so that I can only heat the water tank and not the heating. I'm replacing this...
