Discuss Honeywell Motorised Valve Not Fully Sealed when Closed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
When I have my hot water on and the central heating is off, there is still a small flow of hot water through the motorised valve for the central heating. There's sufficient flow to slightly warm some of the closest radiators. Does this usually mean a new motorised valve or is there something that can be done with the existing valve?
Thanks for looking,
Steve
Yes the whole valve needs replacing
1. You can get just the valve internals for Honeywell valves. Different for pre 1987 valves (no dimple on the cover) from later valves. However, fitting them is just as much, if not more, work than replacing the whole valve.
2. If the last joint on the return pipe before the boiler isn't the hot water primary (non-combi boilers) you can get spurious circulation through some or all of the radiators.
Reply to Honeywell Motorised Valve Not Fully Sealed when Closed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
