Discuss hope somebody can help I'm fitting a kitchen turned the hot water off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi hope somebody can help I'm fitting a kitchen turned the hot water off now it won't come back on the wheel on the valve just keeps turning
snapped gate valve
needs replacing
two options
do it your self or get a plumber in (very common with gate valves)
Thanks the valve is between the tank in the loft and the cylinder is there a way to change it without draining the tank
other than bunging the outlet nope
best way drain down tbh
bath cold tap should be off the cylinder (if old school way still)
Yes, if you want to risk it, try bunging the cold water tank outlet to the cylinder by reaching inside the tank and shoving a rubber bung into the tank fitting. Hopefully the fitting will be uniformly round and not be the rarer type with lugs.
You will still have the water in the pipe to come out when you slacken the old valve nuts.
Or you could buy a basic freeze kit (muff with spray freeze can just)
I will never forget the advice from a former member of this forum on what you could use as a bung for a tank.
He recommended using a parsnip. :grin:
Actually good advice I bet, but never tried it yet.
Carrot or potato works best
just get a professional plumber in bud not a hard job if you know what your doing , you could end up flooding your home
In older house very likely feed to HWC will be 3/4" not 22mm. Make sure you have 3/4" compression olives to go with full bore 22mm lever valve. Moving pipe apart to install new fitting could also be problematic as straining pipe against weight of full CWS tank could result in leak at outlet. Work for plumber, or if DIY, drain tank to give plenty of time to sort out unknowns.
Reply to hope somebody can help I'm fitting a kitchen turned the hot water off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in kitchen only Stopcock in kitchen wall panel turns off cold water supply in kitchen only Red gate valve in airing cupboard next to bathroom turns off...
Hi There was no shut off valve on the tank feed to the hot water cylinder, and I needed to move a couple of hot water pipes, so I shut off the mains water, turned boiler off (Remeha avanta) and opened the hot kitchen tap to drain the cylinder. After doing the work etc, Everything up and...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of copper pipe between compression fittings on the hot water feed. There are take offs for an outside hot and cold tap together with isolation valves and...
Morning, Moved house a few months ago and first issue is having a slight leak on tap in kitchen. Went under sink to turn off water and there are four valves I can see as per attached photos. Tried turning all clockwise 90 degrees as per usual but water still coming out of tap. Am I missing...
Deleted member 120897
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that heats on controlled load over night. The large tank is in roof space of 60s built villa unit. Every few mornings, no hot water will come out of...
