  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss Hot and Cold Water Problem in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. nkhan
    nkhan New Member
    Hello All
    I have experiencing an odd where the hot runs for a short while then it goes cold.
    I had an new Valiant 835 installed around 3 years ago around the same time as my wetroom
    Wetroom shower was fine for around a year and is now intermittent,
    The sink is wetroom is ok.
    Today my bathroom has been fitted and am having the same problem upstairs.
    Someone has advised me it could be whoever installed these have fitted them incorrectly, culd this really be the case.
  2. Matchless.plumb
    Matchless.plumb Trusted Plumber Top Contributor!!
    Hi nkhan,
    Welcome along.
    Does the hot water run only on one faucet hot and cold - intermittent or does run in the whole property like that?
  3. nkhan
    nkhan New Member
    2 now
    The wet room shower and new bath
    The kitchen sink is still ok
    Wetroom sink was ok but now seems to have the same problem
  4. townfanjon
    We call em taps in Yorkshire pal lol
  5. Matchless.plumb
    We call them Wasserhähne in Germany :)
    • Like Like x 1
  6. nkhan
    nkhan New Member
    I am only now having this issue in wet room shower head
Loading...
Similar Threads - Cold Water Problem Forum Date
overflow from cold water tank in loft Plumbing Forum Today at 10:35 AM
Connecting mains cold water to gravity cold water. Plumbing Forum Friday at 6:49 AM
Drop in shower pressure after new cold water tank install Bathrooms, Showers and Wetrooms Aug 11, 2017
Has hot water from expansion pipe damaged cold water storage tank? Central Heating Forum Aug 10, 2017
Low mains pressure but only affecting cold water kitchen tap. Great pressure to outside tap. Looking for a Plumber? Post Jobs Here Jul 26, 2017
Plastic cold water pipe distance from mains electrical cable Plumbing Forum Jul 12, 2017
Water from cold tap is delivered hot Central Heating Forum Jul 7, 2017
