Discuss Hot sync motor on two way valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have replaced the head motor on a two way valve. Is it normal for the motor to feel hot to the touch?
I assume power is constant to keep the valve open, in which case I would expect heat to build up.
Boiler is working fine.
Yes as it needs to keep it open should be cool when the boilers off
Depends on what you mean by hot to be honest. Can you keep your hand on it or would it burn a small child?
Reply to Hot sync motor on two way valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
  • Sticky
