Discuss hot water coming into cistern in the Plumbing Jobs | The Job-board area at PlumbersForums.net
is it possible that the cwsc feeds the woman down stairs as she said she has no water in her bathroom now.since we renovated the guys bathroom.possibly another job to do.so i should hold syphon open to see if boiler fires up?
If I were you i'd run and hide
Bye the sounds of this saga you have cocked right up but the only saving grace you may have is if you have mixed all hot and colds up you can cross at boiler if not get ready to start ripping up tiles and sort it would you pay if it was done in your house don't think so
If it came to the bit and ya had to rip bathroom apart, where would you stand with insurance??
i,ve never had this happen before.and iaint running mate as the guy owes me doh.if i swap pipes at the boiler and washing machine would that sort it?
This reminds me of advice given to me by my ex boss when I'd screwed up big on a job. He took me to one side and said, "At the end of this year are you going to look back and say that was the job that ruined me? If the answer to that is no then you've just simply got to grin and bear it - get on with it, do whatever it takes to sort it out, leave everyone as happy as possible and move on."
Now that's good advice
We don't know you will have to see if you just crossed in bathroom or everywhere!!!
without knowing the piping layout then we couldn't possibly say, well i couldn't anyways, You metioned electric shower earlier in thread and i've asked a couple times does combi fire up when in use and still awaiting an answer
Crossing feeds is easy. Everyone has done it. Luckily I've so far noticed when I run the taps or fill the loo before tiling begins. It pays to be a bit paranoid in plumbing. Check everything repeatedly, all the time. Suspect everything, every noise. Work on the assumption that every inanimate object is out to ruin your day and you should be ok.
agree totally
Can you elaborate on this cold water tank, is this a flat?
Lady downstairs has no water now?
Good advice
Its best to check and double check then check again to be sure only takes 5 mins
its a four in a block house.we left her bottled water till tmrw.the guy wanted the loft cleared of old tanks etc.
the tiler was an rse.rushing us on.
flats often share tanks - bit remiss not to check
you may be able to sort out his prob (or divest yourself of responsibility) with relative ease - if it's just crossed feeds i'm sure something can be done. but re-instating the CWSC to the lady downstairs could be a bigger faff.
Is her kitchen cold tap dry aswell?
It must have been fed from the tank you removed?
The lady without water must be on your customers back, but he only complained about his rotten boiler?
make your mind up fella, is it a worcester or vokera!?
for those of you who may question my tone this gentleman has posted this question elsewhere and some of us have endevoured to help out...then I came across this thread, what gives mrplumberman?
I seen other thread but didn't pick up on the different boilers lol
Reply to hot water coming into cistern in the Plumbing Jobs | The Job-board area at PlumbersForums.net
