Discuss Hot water cylinder number of pipes? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Deleted member 96797
Hot water cylinder in airing cupboard has 5 pipes entering it. 2 are obvious and are the feed and return from boiler. Another 2 are obvious and are the cold water feed and hot out. There is a 5 th that enters the cylinder just above where the boiler feed enters. It has a manual shut off valve. Please advise what this pipe is for and whether it is important to have open or closed.
Thank you
Thanks everyone. A quick test (turn on shower in bathroom) and the pipe got hot. Fairly conclusive. It’s a shower feed.
Cheers
Reply to Hot water cylinder number of pipes? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
  • Sticky
