Discuss Hot Water Not Working Cold only on bottom floors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello
You've probably heard this a thousand times in the last week but I have a cold/hot water supply issue..
We have no water to any taps on second floor (top). Cold water only to taps on first and ground floors.
The hot water tank in the bathroom (first floor) is gravity fed from a tank in the roof space of the second floor.
Does this mean we have two seperate supplies? As why else would we be getting cold water on the bottom floors but not the top?
We have 40cm of snow and I forgot where the mains supply is outside so not going to be easy to locate. Any ideas?
Likely someone will need to get up in the loft and see if anything is frozen. See if the ball valve in the tank is allowing water through. Likely downstairs is off mains and bathroom and hot water is off tank
I have checked the tank and the pipes in the loft and although they feel cold they don't seem frozen. I will go check the ball valve now.
i had a fiddle with the ball valve and it didn't seem to be the problem. Wondering if it might help if I put the heating up and see if I can thaw out the problem?
Is it a dumb question but the pipes from the hot water tank are hot; are they not feeding the central heating radiators with hot water and if so couldn't they feed the hot water from the taps? Probably totally idiotic question.
The pipes going through the cylinder coil are from the central heating. They will warm the water contained in the cylinder
The water from your cylinder only supplies hot water for washing and bathing to taps and showers and is not connected to the heating system (radiators). It's not a stupid question if you don't have any plumbing knowledge.
It seems to me that you have some pipes frozen somewhere, which is causing this.
When they thaw and the taps start running again, I would keep a close eye on the pipe runs, if they are visible, or just generally keep a keen eye out for leaks or damp patches throughout the house, just in case the freeze-up has damaged a pipe somewhere.
Also, as soon as the snow reduces a bit, find that stop-tap to isolate the whole house, and be ready to use it!
Reply to Hot Water Not Working Cold only on bottom floors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the whole house is working as normal. Hot water is working as normal on the ground floor. However, there is no hot water to the first floor bathroom. This...
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my bathroom, and according to the plumber who fitted the new taps, high-pressure taps were fitted. Consequently, the water from taps is of a low volume...
Hi all I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked overflow/expansion pipe. Hence the header tank then reaches the overflow level and the overflow trickles out. I have changed the ball valve washers thinking it was...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering and showing signs of an air lock. I attached cold mains to a hot tap and left it running for 15 minutes, while opening up each hot tap. They all...
