Discuss Hot water pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
RobHum
Hi folks, after some advice. I'm refurbishing a ground floor flat that has a hot water tank in a cupboard. Not a great deal of height and it gravity feeds the bath, wash basin and sink. Bath and basin seem ok as they are quite low. But I've fitted a new kitchen and the flow from the sink mixer tap is very slow. Distance and height aren't good. Does any one know what I could consider an acceptable flow rate. It takes about 2 minutes to fill the kitchen sink with just hot water.
You've fitted a high pressure tap to a low pressure system.
You either change your tap, change your system or live with it.
I guess I should have said the bowl in the sink. This holds about 5 litres
Hi Tamz, thank you for that. I think your right. The cold water pressure is really good. Would it still be ok to fit low pressure tap with the cold being high
Ok. If you're refurbishing the flat and you want better water pressure all round then there's 2 options off the top of my head 1) If your mains pressure is good get a G3 qualified plumber (or 2 or 3) to survey and quote for an unvented cylinder or 2) Fit a cold water storage tank and a normal cylinder and a pump
Thanks for your help Neil. I think that is wise advice. Not sure how much of that I will fit in the cupboard as it is. May have to make it slightly bigger with a stud wall.
Cheers
Plenty of flats in the same situation as you, cheapest way to resolve it is change the kitchen tap for a low pressure tap where the water is mixed at the end of the tap, not at the base. This will help with the unequal pressures of the cold main and the poor head of the hot water.
Thanks for that. I reckon that's got to be worth a try before I do anything else. Cheers
Reply to Hot water pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
