J
jondaniels
Let me start off by saying that I know very little about plumbing, so expect me to struggle a bit with some of the terminology and concepts
Now, to my question: I have an unvented hot water system, with an immersion heater, in a small flat. Recently the tenant in that flat reported that the hot water turned tepid after a few minutes. I have had a plumber, who I have used previously, look at it, and he suggested that I simply turn up the thermostat. However, I was not convinced that this was the problem and indeed the tenant reports that the problem persists. Please note that this hot water system has been working normally for a few years with minimal problems (replaced thermostats, etc)
To me it seems as if the hot water cylinder is simply not getting that much hot water put into it to provide more than a few minutes' worth of hot. The temperature is fine.
Further questions are:
- Is this analysis of the cause reasonable? Is it likely that the how water cylinder is simply not being given that much water to heat each time?
- If so, what can be done about it?
- If not, what might the cause of the problem be? I was told that there is some sort of pressurised sac in the hot water cylinder that helps force the hot water out.
- Might there be some sort of limiter on the hot water cylinder that can be set to allow some fraction of the total capacity of the cylinder of water to come in at a time?
- Might a trapped air pocket cause this? Do I need to bleed anything? There are no radiators of heating - this is just for hot water.
My concern is that I want to avoid having loads of people go to look at it and misdiagnose the fault and charge me for the privilege. I'm trying to build up a picture of what could be wrong so I can confidently get someone in to fix it.
A summary of my understanding of my hot water system is:
- Mains water comes in at 2 bars' worth of pressure
- That goes into a header tank, the bottom of which is probably about 50cm - maybe a meter max - above the top of the cylinder
- A pump draws water from the header tank into the hot water cylinder, also at 2 bars to match the mains pressure, forcing the hot water out into the taps (this was put in because the hot water pressure was initially very low).
- The hot water cylinder is immersion heated, and, I believe, vented. I don;t know the model name of it however.
- When I ran it for a few minutes the other day, the hot water coming into the bath started sputtering a bit. This coincided approximately with the time the hot water started to go tepid.
Many thanks in advance.
Jon
Jon
