Discuss Hoval in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Nostrum
What are people's thoughts on this company, their products etc?
thanks in advance
Haven't used or seen them, had a look at their oil boiler designs and tbh they look very much at the top end of the market.
croppie rates them i think
I'm looking at their new domestic sized pellet boiler range, but haven't had much luck getting a reply to my emails...
They are very well made bits of kit. With the possible exception of the TopGas range of boilers.
The STU and Biolyte biomass's stand head and shoulders above any others I've worked on though I am disgruntled by the fact the concrete arches have a 2-5 year lifespan and cost ÂŁ80-ÂŁ100 per half arch block, they can also go through a pair of ID fan belts every 6 months but these are cheap as chips.
The cast iron tubular boilers with Riello burners are nice to work on and quickly cleaned.
And the Ultragas? I do like a boiler I can stand on and in to service!
However Hoval will advise you to walk away from the TopGas and Ultragas unless you've been on one of their courses.
You'd be able to service the models I'm looking at without a step ladder croppie! They are not even listed on the website yet but they have brought a new range out for the domestic market. 15-36 and 50-70
Do they have a UK base? What are they like with warranty issues etc?
Whats an ID belt?
Induced Draught Fan, sits in the flue of the boiler, there's also a Forced Draught Fan which blows air into the retort, This'll give you an idea.....
Oh, and I've had no issues with warranties with them. They're based in Newark.
Give them a bell! 01636 672 711
There are a few around here, loads of old 60's / 70's vintage stuff, and a few newer things, they are top money though very nice.
If the figures I was given are right they are reasonable compared to the competition such as windhager, eta and froling.
Rock solid bits of kit and well designed. After sales service is pretty good. They have a very good heat recovery rate for residential accomodation, inns, hotels B&Bs etc.
Twickenham uses hoval boilers. Good enough for england rugby then its good enough for me !
serviced a few of tube / reillo burner ones on the nuffield hospitals, nice to work on except on one the door dropped a couple of inches when i opened it and was a ******* to get back in the correct position.
That's why I carry a 4' pry bar and a 6' length of 1.1/2"
Had a tour around their Newark site and lunch out with bosses. Really nice place, high end biomass units.
Reply to Hoval in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just wondered which laser levels are good all rounders for accuracy, ease of use, price etc… Thanks in advance.
Hi, As I need to purchase two new taps for our en suite, I've noticed that almost all taps now come with flexi tails as standard. I've read some horror stories about these bursting / leaking so would prefer rigid fixings like the existing ones they are replacing. I'm looking to purchase this...
Hi all, I have recently returned to the industry and have applied to Octopus for the upskill role into air-source heat space installs. Does anyone work for them on here? Just wondered what people's thoughts were on them as a company and if anyone is fitting air source what they think of this...
Deleted member 120897
UK 6
I wish to add a second boiler to my existing meter. Location 20m away. Underground run. Can l use 32mm yellow pipe with copper tails at each end. Thank you in advance
Hi. I get a slight leak of water in the bowl. Any advice re the attached please. Thank you in advance
