Discuss How difficult is it to remove this?! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
BD1978
Doing up the bathroom and discovered this boxed in. How easy is it to remove? Guessing it's the original waste water pipe system. It's an eye sore and takes up space. Is it a complex job to remove it and install a smaller neater alternative?
that's your main 100mm (4") drain cast iron even if you manage to remove the iron branch you will still have the same size but in modern plastic , is this on ground floor because that cast iron will go down to ground level, and will require special tool to cut into it not something for DIY I'm afraid
Thanks. It's on the first floor so from your guidance I guess it runs down through the house to a drain. Thanks for the info.
Would this pipe normally be on the outside of the house or is it common for them to run internally?
Yes it would, at sometime in the past its gone straight up through the roof it may be possible to install a new external soil system but that would be expensive
That is beautiful. Back from the days when plumbing was built to last. Wish my house had such a nice soil and vent pipe.
I bet the gasket on that inspection/rodding eye is a greased felt material, and I bet those bolts will still unscrew after all those years (if you use a ring spanner and some care). The wall of that cast-iron pipe is probably half an inch thick, deadens the sound of running water and will continue to give good service until it rusts through in another 5o years or so.
The plastic pipes inserted into it are probably a recent modification (defacement).
As others have said, if that is your bathroom, the pipe will be needed somewhere. You could put a new one in, but you can't do without one, assuming you want a flush toilet.
Reply to How difficult is it to remove this?! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
