Discuss How do I access the washers on this bath tap please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Advice appreciated. See photo.
I cannot find any way to access the washers. Thee covers do not seem to be removable. There are no screws t be seen.
cant see any screw or cover from pic so knobs are probably just pushed on. it may take bit of force and persuading as probably they are limescaled. good luck.
Thanks guys!!!! It pulled off with difficulty, but I had been scared to try before I got your advice. In fact, inside is an Ideal Standard 963400NU headwork ( cartridge ) - see pic.
I think the drip problem is associated with the ring washer highlighted.
It seems to be 20mm diameter.
Does anyone know the exact spec?
Your help has been greatly appreciated§
I doubt if it is that O ring pal , but if it is , those are easy to source.
Ring ideal I have always found them very helpfull .
Thanks again guys - I fixed the drip - possibly will re-occur, but fine for now!
Not having new O-ring I cleaned the scale from the thread near the O-ring, then used a small screwdriver to raise the O-ring around its circumference, to make it more proud, then ran some vaseline around the ring - replaced the unit - and the drip has stopped.
Without advice from you, I couldn't have done it!
Well done. At least if it fails again you now know you can change it for a new cartridge if necessary, now you have the knowledge.
The bottom seal washer - (a sort of soft white rubber washer) is what often deteriorates with those works. If the compression then is lessened against the ceramic works, the tap will drip. I have replaced that washer as a temporary fix, but not worth the bother
Reply to How do I access the washers on this bath tap please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need to replace the washer of my kitchen mixer tap as it is leaking. I was able to remove the spout once by unscrewing the screw on the back of the tap. However now I can't remove it again as it seems I must have used the wrong screw head and have rounded off the head. Please see attached...
I need to change the washer on the dripping hot tap in the photo, does anybody know how to remove the dome tap handle, there's no fixings or grub screw anywhere, thanks
Hi. Can anyone help me get into this tap? I have them on the bathroom sink and bath and 2 out of 4 are dripping. I've have had two plumbers in to replace the washers and neither could get them open. The gold coloured ring under the top unscrews on two of them but won't budge on the ones that...
I have a wall mounted bathroom tap that leaks. Presumably I need a washer of sorts replaced. I cannot work out which tool I need to remove the tap. There is a small hole (8mm?) to the side but I can’t seem to get a fixing from either a alum key or screwdriver. Ever hopeful…? Matt
I have a slow leak in the bath. Its a mixer type set up. I'm unfamiliar with the tap handles and how to access the cartridges etc. If I can work out the product name/brand/type then I can work out how to remove the tap handles (no obvious indices so presuming they pull off some how). Would...
