Discuss How do I remove these covers? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Thread Status:
  1. finchy01
    finchy01 Plumber GSR
    Sat in a customer's bathroom trying to replace their concealed thermostatic shower. I've removed the 2 grub screws (1 on each) but can't shift either of them. I've been trying one for about 15 minutes now so can't believe it's just scales. The new replacement (looks identical) is just the 2 grub screws. What am I missing? Thanks ad always. Ben
  2. ShaunCorbs
    If you have a full replacement kit and don't need anything from the old one either snap or cut the old nobs off
    • Like Like x 1
  3. steadyon
    steadyon Active Member
    Some used to use two grub screws, one after the other. Tighten up with the first one then lock with the second.
    • Like Like x 1
  4. kris
    kris Trusted Plumber GSR
    Slide the cover off first , this will show you if youve part to unscrew or simply pull the heads straight off and yes its only the grub screws holding them on so they'l probably just be stiff,
  5. moonlight
    moonlight Plumber GSR
    Just grub screws, just pull a little harder.
    • Like Like x 1
  6. finchy01
    I guess I need to eat more weetabix! Got it off when the red mist started setting in! Thanks chaps.
    • Like Like x 1
    • Funny Funny x 1
Loading...
Similar Threads - remove covers Forum Date
CANNOT REMOVE TAP HANDLE HEAD (BONNET TYPE) Plumbing Forum Mar 22, 2018
How do I remove this dishwasher without flooding the kitchen? Plumbing Forum Mar 10, 2018
Thread Status:
