Discuss How Do I Shut Off My Water Supply? in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. BlackEarth
    BlackEarth New Member
    Hello!
    I'm planning to replace my bathtub mixer, but obviously need to shut off the water before I begin. There are no valves for the hot/cold water pipes in the bathroom.
    The problem: I'm in an apartment and my water tank is old (circa late 80s/early 90s). I can't figure out what needs to be done to stop both the hot and cold water. I'll attach some photos. Any help is massively appreciated, this forum has become somewhat of a lifeline as of recent!
    Imgur
    31641062_10216345542698356_3476458370330787840_n.jpg 31517063_10216345542538352_5019935390195253248_n.jpg 31490547_10216345542258345_5656370374330286080_n.jpg 31440223_10216345542018339_5227715462615269376_n.jpg
  2. scott_d
    scott_d Plumber GSR
    Looks like the stop tap under the water meter
  3. BlackEarth
    That was what I thought, but will that stop both hot/cold or will I need to drain the tank? Would prefer not to drain the tank if it's possible.
  4. scott_d
    scott_d Plumber GSR
    That should shut the cold into the cylinder and therefore the hot out.
    Turn it off and try opening the bath taps
  5. BlackEarth
    That's done the trick! Thanks.
Loading...
Similar Threads - Shut Water Supply Forum Date
Water Flow dramatically changed taps full of blue plastic HELP Plumbing Forum May 10, 2018
No hot water from tap when shower in use Plumbing Forum May 9, 2018
