R
Rickster123
Haha offensive?! If you get offended by that I'd like to apologise for this.... :ciappa:
Cheer up!
Cheer up!
Discuss How to drill the the BACK of tile ALREADY installed onto masonary wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Not insulting me only YOUMe and everyone else on this forum mate - you included!
Lets not get our knickers in a twist shall we . . . .
365 drills I apologise!
Kindly remove that offensive picture however as it does not show you or the forum in a good light . . .
Yikes!
That's a word BATMAN would useYikes!
Yikes!
I think I'm going with the voyeur camp of thinking........
That's a bummerHA HA, I drilled out a 22mm hole to get a prv blow off out through a stone n rubble wall today, took a wee while, over 20 mins and when I finally broke through, I trotted downstairs to inspect the exterior result and it looks like Ive got some rendering to do next week! 1/2m2 of thick render popped off the wall, must remember to to bring my cores in the van next time
I think he has gone to the effort of drilling up to the tile from behind ,why not live the drill bit into the hole and with a metal detector point exactlyWell we just had the customer feedback and he said it "Did a beautiful job..."
He explained "We already had one of your bathroom fitters kits here on the job with a 16mm 30mm and 40mm drill. So We used your 30mm to take a slug out of the first tile and expose the masonary brick behind (breeze block). We DIDNT use a 16mm masonary bit. In fact we used a 19mm masonary drill bit to bore out the hole all the way through the blockwork until the tip touched the tile in the other room.
We cleared out the 19mm hole so we could see the tile. We inserted that 16mm diamond core that you supplied above and sluced water down the gap. The 16mm bar rested on the masonary (didnt kick up or move) and we slowly bored out through the back of the tile squirting water down the hole as we went.
The hole formed very quickly even though this is one of the hardest porcelain tiles I have come across. And when the diamond core popped out of the other side (the front of the tile) there was a perfect hole. No blow out. No chips. Nothing shattered.
Really pleased with the results and we want to now order a full selection of other sizes from the PORSADRILL range.
So I think we have a happy customer.
... and a lovely sponge...
That sounds like a euphemism to me. Dirt bag!
Is the sponge nice and moist?
Reply to How to drill the the BACK of tile ALREADY installed onto masonary wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
