Discuss How to use existing oil boiler for UFH in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm renovating my house, taking out the wall mounted radiators and fitting an underfloor (in screed) heating system, but I want to keep the existing oil fired boiler.
If the UFH needs water at 25c and the boiler delivers water at 60c how do I avoid over heating the floor?
Can I fit a reservoir/tank in the UFH system so that the boiler isn't constantly turning on and off?
It's all possible provided you get someone competent to design and install it for you. If you are planning on doing this yourself, I would recommend reading the appropriate literature or going on a course.
Reply to How to use existing oil boiler for UFH in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
