Discuss Human faeces Leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just wondered if anyone could help. I was decorating a flat today and noticed this in their garden. I don't know anything about plumbing but is this a soil pipe that's leaking sewerage into their garden? What could have caused this to happen and what would be the best course of action to take.
Thank you
The connector has fallen apart.
The plastic ring lower down the pipe that's being held up with a drain rod, belongs on the straight connector to hold the seal tight.
It needs a new straight connector fitting.
Thankyou for the quick replies it is very much appreciated. how much roughly can the landlord expect to pay a plumber to carry out this work?
Thank you
Did you do the taste test?
I didn't but I poked it with a stick and it was soft in texture so I ran. Is this a major health hazard? Could someone get cholera from this?
Whats occurring here .... that looks like a drain rod around the back of the pipe and something is wrapped round it
Whats occurring here .. that looks like a drain rod around the back of the pipe and something is wrapped round it
Maybe somebody has used drain rod to show the rubber seal, to keep their distance
Sorry bud slip of the finger "rpm"put the op out of his misery how much for the repair ?. Kop
Reactions: rpm
I enlarged that photo and the "rubber seal" turns out to be not that at all, but it is the plastic retaining part of the connector, broken and upside down.
Looks like someone has attempted to put it back on
Yep something fishy here ... “wind up “
I mean Rubbish has literally been leaking into their garden for god knows how long . How do people live like that. What's their affliction?
Perhaps they are trying to improve their soil? I would prefer a properly-managed compost toilet to a smelly mixture of poo and water though!
It does need a new coupling as suggested but it could more easily be fixed with a rubber soil pipe coupling and that would avoid having to shift the pipe vertically, just shift the pipe horizontally and slip it on after giving it a clean first obviously. I was going to suggest jet washing but then you don't want Rubbish flying all over the place, it'll have to be a bucket of suds and a stiff brush to the lucky tradesman.
Reply to Human faeces Leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, the edge of the end of my bathtub leaks when I am about 3 minutes in the shower. The faucet is on the opposite side. What could be causing this? I had someone take a look at it today but could not figure out where the leak is coming from. The odd thing is there was no leak when we had...
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the radiators but still gave hot water to the shower and taps. Naturally we thought there was a fault with the boiler. We had already arranged a yearly...
Hi guys not sure anyone has encountered this before but I have a job where the inside wall has been getting a little damp, there was a step up to the door that I think wasn't helping due to dpc but that was removed to take a closer look and it revealed 2 waste water pipes going into the patio...
I recently had a plumber come over to look at a badly leaking shower head. As best I can recall, he described the problem as a crack in the bridge of the cold water pipe and explained that there were two options: 1. Get into the wall with a jackhammer to fix the problem; or 2. Install one of...
We had the bathrooms replaced when we moved in 2 years ago. This involved 2x bathrooms and 1x WC. Within the first few weeks, we noticed leaking from the en-suite down into the reception room and the fitter promptly came and repaired it, it was something to do with the area under the sink. We...
