Discuss I really need your help. Gas related (Heat inputs etc) in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Lee McCormack
    Lee McCormack New Member
    Hello everybody,
    This is my first post and as ive noticed a lot of people are very critical when people ask questions please have my assurance i have been studying for about a week and im simply trying to get ahead.
    I have been given a MI sample which is found on a boiler which reads the following
    Range rating . Min . Max
    Heat Input KW 16.3 19.1
    Heat Output KW 11.7 . 16.4KW
    Hot burner pressure mBar 7.4 . 5.2
    Im a little confused by it all even after looking up other posts what it means by heat input and heat out put etc.
    Am i correct in saying that the burner pressure is measured on the the outlet port of the gas valve and this checks the pressure of which the burner is operating at ?
    Regarding gas rate is this the same as heat Input ?
    Thankyou guys
  2. ShaunCorbs
    simple way to look at it
    heat input simple way to look at this is the input of gas
    heat output how much heat is the boiler producing for the system
    burner pressure is normally tested on a port either p2 of the gas valve or on the burner tube (normally a test point on the tube going to the burners)
    and yes but will be in m3/h or ft3/h
    lets say you do your gas rate and you get 1.64m3/hr to turn this into a kw rating
    1.64 x 10.65 = 17.46kw
    etc
  3. chris watkins
    chris watkins Plumber Top Contributor!!
    Lee what are you trying to get ahead off ?
    Input is the amount of heat energy release when the boiler burns the fuel.
    Output is the amount given out to the water or air.
    This gives you an idea of how efficient it is.
    We can't answer the burner related questions as it is open forum.
    Edit - (Or maybe Shaun can)
    • Like Like x 1
Loading...
Similar Threads - really need help Forum Date
I need to find a macerator that can deal with bath... Sanitary Ware Yesterday at 8:32 AM
Need assistance with cylinder config Plumbing Forum Saturday at 7:15 PM
