Discuss I thought you couldn't pump mains legally? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
So why is this allowed to be installed?
Salamander Pumps HomeBoost HB Booster Mains Water Boosting Pump 1.6bar
Thought it was the amount of water per minute that is limited.
Is it because you are allowed to, subject to the water undertaker's permission? Although manufacturer's website claims you can pump up to 12l/m and this pump is limited to 12l/m. Need to re-read my blue book (again!)
Reply to I thought you couldn't pump mains legally? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Background I have a small one-bedroom flat in the roof space in a victorian house. There are three floors below and each floor has a single one-bedroom flat. The mains pipe bringing water into my top-floor flat is 15mm copper pipe. There is a water meter in the flat and a stop valve. There is...
Hi there, I’m hoping someone can help me with this problem please. I’ve searched for similar posts but not found anything helpful! My mum’s house has a pump which pulses on and off every time a tap is opened. Even filling the bath (pressure is strong) the pump won’t come on and stay on but...
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater systems in the house. This boiler was replaced by a combi boiler as it only heats the lounge and master bed and provides hot water to en-suite bathroom and...
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A gardener/landscaping friend of mine is going to install an irrigation system in a customer's garden. He asked me to pop around and measure the pressures and flowrates...
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar. Connect to this is a 1.5 bar Ora Salamander pump for a positive head, this was connected by a plumber of course and we’ve had it all rigged up...
