Discuss Ideal logic 30 frost stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Deleted member 94038
Does anyone know if the logic 30 has an internal frost stat?
It has built in frost protection but not a frost stat as such. If the temp gets to 5degrees the boiler circulates but in theory it only protects the boiler and not the whole system.
Thanks so would it be advisable to fit a frost stat. The boiler is in the loft so want to be sure it and the system is protected before the winter
Frost stat, pipe stat, insulation and condense should be sized correctly and possibly insulated.
It was fitted in June. The condense has loads of fall and all the pipework is insulated.
I would fit one but that’s how I’m built. You have to be Gas Safe Registered to fit the Frost stat as the case has to come off.
Edit due to spelling mistakes
Reply to Ideal logic 30 frost stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know a good, not super expensive, leak detection company in the London area?
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
