Discuss Ideal Logic Combi 24 problem in the Gas Safe Register Forum - Public Forum area at UKPlumbersForums.co.uk.
Tags:
  1. Paul Cockhill
    Paul Cockhill Member
    Hello
    I am a plumber but not a gas safe plumber . I have recently changed a shower room into a bath room in my niece's house. The job went well but now we cannot get any hot water out of the boiler to any of the taps. This despite the fact that the heating is working.
    I have done nothing to the boiler ( I know it is illegal of me to touch the boiler and I would not know what to do anyway) I did turn off the boiler when I had to drain down the pipework to alter the pipework. However I bled the air out of the system and the hot and cold worked fine.
    However now the setting stays at O on the display although you hear the boiler coming on the water stays cold.
    The only other thing I have done is change the direction of the condensate pipe, which still feeds into the bath waste as before. It just joins the bath waste a little before now
    Anyone have any thoughts
    Paul
  2. scott_d
    scott_d Plumber GSR
    Cold from the hot tap or no water at all?
    Did you reopen all valves?
  3. Paul Cockhill
    Hi Scott, Yes I have opened all valves. There is cold coming through the hot taps
  4. scott_d
    scott_d Plumber GSR
    Have you got pressure in the heating?
    What does the boiler do when you open a tap?
  5. Paul Cockhill
    Hi, I am not at the property but my nephew tells me that the heating is working fine. When he turns on the tap for the hot water, it briefly comes out hot then turns cold again. The boiler fires up but the display shows O
    Paul
  6. scott_d
    scott_d Plumber GSR
    Sounds like you need someone to take a look at it
  7. Paul Cockhill
    Hi, I have just found out that the pressure is 1.5 bar and when the hot tap is turned on the boiler does not fire up and cold water comes out the hot tap
    paul
  8. S.P.S.
    S.P.S. GSR
    If the heating works, pressures at 1.5 and it’s displaying “0” (standby) when you demand hot, And it was all working perfectly before hand..
    Erm you haven’t accidentally tee’d the hot and cold together any where have you? Go to the boiler, turn off the cold inlet isolator to the boiler and see if water comes out the hot taps..
    If it does, then that’s the issue.
  9. Paul Cockhill
    Thanks SPS, I will check today. I dont think it is the issue as I checked the new hot and cold feed to the bath taps before I fitted the bath but I will check it later. Could it be possibly anything else?
    Paul
  10. Jones82
    Jones82 GSR
    Look to the boiler filling loop, its built in on the logics pipe work, you will have used it to refill the heating. You have to turn off the cold water inlet to the boiler to get it to fill the heating and its commonly left off which results in no water coming out of the taps.
  11. S.P.S.
    S.P.S. GSR
    True but they have cold water coming out the taps!
    These suggestions are the only things I can really think of with out getting a gsr plumber out.
  12. Paul Cockhill
    Thanks Guys. Will try your suggestions
    Many thanks
  13. johnduffell
    johnduffell Member
    A short burst of hot then cold, but boiler not firing up, sounds like it is warm due to pre heat/comfort mode, but not detecting any flow from the dhw side to fire up.
    If you can check without opening the combustion/flue path, check the dhw flow valve and inlet screen for foreign material and connection in good condition. Could be some lime scale dropped back into the flow turbine and Jammed it
Loading...
Similar Threads - Ideal Logic Combi Forum Date
Ideal Logic Combi - Low Working Pressure Gas Safe Registered Plumbers Only Aug 2, 2018
Ideal Standards toilet, part required? Plumbing Forum Saturday at 4:00 PM
