Discuss Ideal logic + Heat 18 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
It is an electrical connection. But you need to be Gas Safe Registered to access the connector block.Ok I thought that a frost stat was an electrical connection. If it was an external stat.
Depends on a number of factors mate. Best to get someone in to have a look.I understand now. How much do they cost are. Do they take long to install.
Might invalidate the warranty on the boiler if you do not have one.No its not insulated. The boiler is in the garage. The garage is a new build. So not likely to get cold in there. But iv heard it's always best to have a frost stat if the boiler is outside the house.
Then they must be blindOk thanks for advice. Only asked original question. As someone on the Web said it had a built in frost stat. And as they could not see an electrical connection for the cable.
Reply to Ideal logic + Heat 18 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
