Discuss Ideal Standard Mono block tap flexi? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello ,
Bought a ex display tap and sink the other day and I was wondering what Flexi pipe I need here. I want a compression fitting the other end but what goes at this end.
The end with the o-ring is threaded and it copper pipe looks like it pressed into the casting of the tap.
If anyone could send me a link that would be great.
Many Thanks
Why does that tap look strange? Aren’t English taps normally female inside the tap and require 12mm male flexi’s? Or am I missing something? Where did you get it from?
Reactions: rpm
Homebase on an Ideal standard Sink as an ex display. Yes I thought there should be female holes and not males. I can't find a Flexi to fit....
Can the braided hose come off the tails leaving the Brass fittings in the tap guy's ?
Never seen it before. I would try and take them out. But that’s just me. Or call Ideal standard tech department.
i would say they have to come out
your not going to find anything thats going to be easy
the brass will either be m10 or m12 (normally m10)
Had a good spout of m12 recently mate. All when customers have called me to fit only and brought online. They could be m10 But i have s**t for brains and poor eyesmost of the time :D
yea just depends how much space they have :D
Looks like someone has pulled off the braided hoses.
The inserts will unscrew out and should be 1/4 (8mm)
My guess is that's an 'easyfix' tap, made to be able to fit from above (sort of) there's a base part that it goes into, the tails attach to the base, not the tap.
They don’t have the 8mm threaded rod that goes through the worktop
Reply to Ideal Standard Mono block tap flexi? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
