Discuss Ideal Vogue/ Nest wiring help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys looking for a bit of assistance if possible. I've got a client who is looking for an Ideal Vogue C40 gen 2 with weather compensation and a Nest gen 3 to be fitted. I've never fitted either of them before so unsure of the wiring. The Nest is not replacing any existing thermostat so I will be running a new link between the Heat Link and the thermostat. If anyone can shed some light on it I would really appreciate it.
s-plan-wiring-ideal-vouge-with-nests-png.30935
That should give you an idea, if your still stuck will draw one up for your system
I my be missing something here but why cat the live supply to the nest controller not be connected to terminal 2?
Reply to Ideal Vogue/ Nest wiring help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
