Discuss identify back nut size please? (bathroom sink waste) in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. ColdEagle
    ColdEagle New Member
    hello,
    my basin pedestal sink has been leaking finally managed to edge the stand forward and have identified that the black back nut is split into two. this holds the 'top' of the waste pipework to the bottom of the sink?
    across the middle its roughly 2 3/4 inch and from outside edge of nut (the straight sides bit) its 2 inch.
    I am struggling to locate this anywhere, my local merchants don't stock them nor do the 'sheds' or screwfix, so am looking online (amazon preferred as next day delivery) but cant seem to find any this size, ebay have some but I don't know how they measure if its middle or outside nut edge?
    can anyone direct me please? maybe I'm looking for the wrong thing? or measuring incorrectly? It doesn't look like an old sink?
  2. ShaunCorbs
    Best was is to replace the whole waste piece Don't think you will be able to just buy the nut on its own
    If you buy the whole waste you should be able to remove the nut and use it on yours
    • Agree Agree x 4
  3. Dkdc71
    Dkdc71 Member
    A standard waste grating
  4. jtsplumbing
    jtsplumbing Plumber GSR
    Isn't Plastic wonderful Just get a complete new Basin waste ask if they have one with a Brass back nut
    • Agree Agree x 1
  5. S.P.S.
    S.P.S. GSR
    It’s a standard 1 1/4” BSP back nut.
    Most decent local merchants will have one. Some of the bigger chains are useless
    But I agree with above, change the waste.
    Brass Flanged Backnut
  6. Gasinspect
    Gasinspect Member
    And use the screwfix waste fitting kit, which is saves a lot of messing around with ptfe and sealant, even our new plumbers on site get it right first time, bargain for £1.99.
    • Like Like x 1
  7. Stigster
    Stigster Plumber
    A plus 1 for the waste fitting kits. I used to use Plumber's Mait and an Ablex washer until I found these things. Very reliable seal.
Loading...
Similar Threads - identify size please Forum Date
Can anyone identify this Redring boiler? Central Heating Forum Friday at 5:27 PM
Help with identifying gas fire Make Plumbing Forum Sep 11, 2018
  1. basin waste nut size
