Discuss Identify bath panel in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. hENRYDAC
    hENRYDAC Henrydac
    Can anyone point me in the right direction to find a replacement panel for this bath? It is 533mm deep and 1700 long. A standard P shape will not fit.
  2. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    You have probably checked already but are there any markings on the bath behind the panel to say what make of bath it is?
  3. hENRYDAC
    hENRYDAC Henrydac
    No marks and customer knows not from whence it came.
  4. rpm
    rpm Trusted Plumber Top Contributor!!
    If it is cracked or damaged then past suggestions has been local car bodyshop to repair and brace it from behind.
  5. quality
    quality Plumber GSR
    looks like it has yellowed with age probably, but I am not a bathroom boffin but mine did the same in my own house
  6. hENRYDAC
    hENRYDAC Henrydac
    Thanks for your responses. Yes it has yellowed. unfortunately, not seen in the photos, is the fact that the other end of the panel has been cut back, such that it will not conceal what it should.
  7. turnpin
    turnpin Trusted Plumber
    If there's a basin or toilet in the same room check for make or marks to identify it may have come as a suite....regards Turnpin:)
    • Like Like x 1
Loading...
Similar Threads - Identify bath panel Forum Date
Can anyone identify this Redring boiler? Central Heating Forum Friday at 5:27 PM
Help with identifying gas fire Make Plumbing Forum Sep 11, 2018
