Discuss Identify these taps Please. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone identify these taps? They are leaking and I can find no way to get at the cartridge. There are no grub screws. The pix show the whole kit plus 2 closeups 1 with the rear collar slipped off. Thanks in advance.
Forgive me if im.wrong but does the centre part covering the spindle wind out for you to be able to get a spanner on the threads?
Hi, Thanks for the response. My assumption was that the part nearest the wall should be restrained with a boa wrench or similar and the other, equal sized part in front of it wound out. Otherwise the grouting would be damaged. But. I didn't want to try this out without trying to find out if this was correct. In the end I might just have to have a go. trouble is if I do break something I don't know where to look for a replacement.
Reply to Identify these taps Please. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
