K
k13wjd
Hi guys, nice easy one for you ( i hope)
I'm in the middle installing a heating system, and a new bathroom at the same time.
This morning i needed to move some old pipes - these are pipes which used to connect to an old asbestos tank ( one mains cold pipe in, one water feed out)
When the tank was removed, the person simply connected the 2 pipes together, using 22mm HEP plastic fittings. Great. But the pipes appear to be 3/4 inches ID - so about 20.5 ish OD......
However, I need to move the connection, so i can install the rest of the plumbing. So, cut a long story short - whats the industry standard of changing a 3/4 inch pipe to metric. the ideal for me is to buy 2 off, 3/4 imp to 22m metric fittings, Preferibly yorkshire ring solder type ( in keeping with the rest of my new pipework. I can then insert a 15/15/15mm T into the join, creating a feed for my boiler.
any advice ?
any advice ?
