Discuss Indirect cylinder heating problems in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Hugh Hair
    Hugh Hair New Member
    Boiler has 28mm pipes to indirect cylinder gravity feed. Pipe exit from boiler is hot (boiler stat no5). Hot water cylinder not hot enough, boiler running 24 hours continuously. Problem only started, previously piping hot. Can only think there is a blockage or restriction in pipe work, but seems unusual in large bore copper. Any ideas?
  2. Darren Jackson
    Darren Jackson Plumber GSR
    Thermostat on boiler been turned down or faulty?
    Thermostat on cylinder Faulty?
    Blocked feed pipe from header tank?
  3. townfanjon
    Have you drained the system down ?
    Header tank 1/3 full of water ?
  4. Best
    Best Trusted Plumber
    Things that need checked are, -
    Is there a few inches water in expansion and feed tank?
    Is there water at top connection to coil?
    Is there a blockage in the feed pipe?
  5. jtsplumbing
    jtsplumbing Plumber GSR
    As B4 small tank in loft is empty and water level in pipes is to low to let it gravitate
  6. Hugh Hair
  7. Hugh Hair
    Many thanks guys, header tank empty. Filled up ok but will probably fit new ballcock. Problem solved, thanks a million
    Hugh
    • Like Like x 2
  8. Best
    The older ballvalves that have brass pistons inside them will tend to seize up easily on heating tanks, as the valve rarely needs to replenish water
    • Like Like x 1
    • Agree Agree x 1
  9. quality
    quality Plumber GSR
    I agree entirely, whats better to fit is a modern foreign valve that will fail and never shut off after a couple of years, that way it will need replacing again lol
    • Funny Funny x 2
  10. spanner
    spanner Plumber GSR
    Check emitters are all okay might need a tweek of a bleed after topping up the f&e.
Loading...
Similar Threads - Indirect cylinder heating Forum Date
Pipe size for unvented cylinder and boiler Central Heating Forum Sep 10, 2018
Nightmare trying to connect a portable gas BBQ to a butane cylinder Gas Safe Register Forum - Public Forum Sep 7, 2018
